Caller Id on 721 | SatelliteGuys.US
Caller Id on 721
VonL
30
I have talked with Tech Support several times about why Caller Id will not work on my two 721's. This last time they told me it was a grounding issue. I checked everything and all appears well but still no Caller ID. By chance I have a 501 which I hooked up to see if Caller Id would work. I used my cell phone to call my home number and it worked fine. Hook the 721 back up and nothing.
Any ideas as too what is causing my problem(s)?
Thanks,
I have no real help. but try this. Disable callerid and exit completely out of the setup menus. Then go back and re-enable it. Let me know if this works.
caller id on 211
my caller id on my vip 211 has never worked either. I had the 211 replaced and it still didn't work. Anyone else that this problem. My 622 works fine (caller id)
I have the same problem with my 2 721's.
It occasionally works for a while and then stops for a while.
It seems to ALWAYS work after I restart and then stops a while after that.
I just received another 721 after my original had a hard drive failure. Caller id has not worked on it at all. I guess I'll have to get by without even though it was nice when it was working.
What can I expect from dish HD?
$549, 921 - Did you Buy?
