T Tommyboy SatelliteGuys Pro Original poster Sep 25, 2004 338 13 Oct 16, 2005 #1 what kind of signal will i get with a 75 cm (30-inch) Elliptical Antenna down here in miami fl.?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,452 15,117 Mankato, MN Oct 17, 2005 #2 before they swapped satellites, I would say pretty good (+9 or so) SC mostly uses EbNo numbers...+5 is minimum and 7.5 is real good but with the new satellite, unknown. Check the sticky at the top to see if someone posted their strengths for Florida
B bwaldron SatelliteGuys Guru Aug 18, 2004 120 0 Brandon, FL Oct 17, 2005 #3 In Tampa, anyway, both satellites come in fine with the 75cm dish...and the recent satellite switchover has improved the signal level a bit. Tommyboy said: what kind of signal will i get with a 75 cm (30-inch) Elliptical Antenna down here in miami fl.? Click to expand...
