C Band settings for my Coolsat 6000 P | SatelliteGuys.US
bloomdog
306
I am experimenting with the C Band portion of this LNBF on my 1.2 m dish:
BSC621-2 C/Ku LNBF
C Band
Input 3.4~4.2 GHz
Output 950~1750 MHz
LO 5150 MHz
What setting do I use on my Coolsat 6000 Premium for the lnbf (c-Band)?
Thanks!!
SINGLE
5150
Diseqc port 1 if no diseqc attached (it sounds weird just trust me)...if you run it into a switch then its the port you hooked the cable to :)
A quick install question.
Visionsat Iv 200 Pvr
