C-Band NPRM | SatelliteGuys.US
C-Band NPRM
comfortably_numb
21,447
34,497
Kansas City
Currently staying on the 9th floor of The Strat Hotel in Las Vegas. Outside my window there are 4 C-band dishes on NPRM's (probably for the sports book).
Never seen an NPRM for a C-band dish before, so thought I'd share :)
Reactions: comfortably_numb
.....I wonder what those NPRM cost.
You can buy from here:
Sent from my SM-G950W using the SatelliteGuys app!
Hi a forum members is selling some.
Considering the prices for new ones, that's a bargain if you live local and can pick it up.
Reactions: martin-f and FTA4PA
There are a couple hundred plus 4.5 meter C band dishes in the Alaska bush, there are no traditional building materials available usually "rock boxes" are used to anchor them down. A variety of surface mounts are used whatever works.
I mounted an 8ft CM offset on railway ties buried just below ground surface. Hasn't blown over yet! Likely not best for a rooftop though can't bury anything there unless you can tie into the roof structure somehow.
Shouldn't be difficult to weld something like post #6 with some material from a local scrap yard.
Reactions: martin-f
Here is a link to the NPRM install at the Ti shop. Added three safety chains tied into the rafters to minimize the chance of a fly-away, but it has never shifted even in heavy winds. Five years later and still tracking the arc.
Here is a link to the NPRM install at the Ti shop....
The only thing more beautiful than a 10-foot mesh is one on top of a roof in the clear able to see lower on the horizon.
I took one like that to the dump before my last move. I stupidly thought it would be too awkward to move cross country. When the 80-foot moving truck arrived, I realized my mistake.
Reactions: martin-f
Getting Started (Advice?)
Is my LNB mounted properly? What else could be wrong?
