C-Band LNB | SatelliteGuys.US
C-Band LNB
soyticodepz
21
I have just bought a 1.8m channel master dish. I have a pansat 2700A reciever. What lnb you recommend for c band channels? Do you think I will be able to get pas 3r and intel 805 with it? Also, is there a motor for the 1.8 m dish?
I need help, as you can tell I am new here....But I am having fun with the 76cm dish and the ivacom lbn I have, of course I want to get into c band now......thanks for your help.
Can I use this lnb with a 1.8m channel master dish (I don't know what a offset dish is by the way) and a pansat 2700A?
Can I motorized the dish? What do you recommend? I want to get pas 3r and intel 805 sats.
Yes you can use it with a 1.8m dish depending on what kind of LNB holder you have. Have a look below for a picture of an offset dish.
ok, I have a better idea know. The dish will be delivered this week, so as soon as I get it I will know if it is a off set one.
What motor can I get for a 1.8 m?
There are different types depending on the dish. I use a 24" actuator on my 6' (1.8m) dish.
How Does Your Receiver Scan in Existing Channels with New PIDs?
Found Directv dish in trash - useful for fta ?
