Does anybody know if it is still possible to receive Directv progamming using a c-band dish? I ask because awhile ago I saw Skyvision selling an adapter to receive DBS programming.
My Directv dish uses the single lnb to pickup the 99,101, and 103 satellites. So, I am not sure if that would be a issue. The good question is if I found the adapter is it capable of receiving their HD signal?If I recall that adapter allowed you to attach a directv lnb to your dish.
Not sure how it would work now since directv now uses a 5 lnb setup using ku and ka band.
I won't say "no" for certain, but I'll bet it came with a little dish.
Generally, it's unwise to try to mix FTA & DBS reception on a common dish.
At least for dishNetwork, their receiver is always hunting for signal, and it get very upset if the bird is lost.
ALSO, no DBS installer would troubleshoot anything but a stock-standard configuration.
Last but not least, most of DirecTV is now on a couple of Ka band birds, and alignment is critical compared to Ku.
Edit: if you just want 101w Ku (standard def), put up a stock 18" and be done.
iPhone 4
sounds like a misaligned dish....The reason I would not mind doing this is because of long outages with their HD signal
Sounds possible.sounds like a misaligned dish....
there was and probably is one out there, at the time it sold for 70 -120 it was built right into the scaler , i tried to hook one up just placing it ( mounting it beside my scaler on my c band dish ) reception was bad in the mid 60's with a 10 ft dish that was just a single lnb built into the scaler nowdays multiple lnb setups that dtv is using its not likely a good investment and i'm certain no hd from it maybe sd with the single eye lnbf
i wouldn't use it but ..... your mileage might vary scaler ring
Not necessarily. Down here in the sunny South rain fade is a real problem with Ka. Its one of the reasons I dumped Directv. I had 99-100 signal on all TP's and a anything heavier than a gentle rain dropped the signals to 0's across the board. I have talked to other people with the slimline dish and Ka HD and they all say the same thing, get a book when it rains unless you are watching SD/Ku.
Although I am not all convinced that a 1.0 or even a 1.2 solid would work better on Ka. Even if you could figure out how to make the separate dishes talk to the receiver.![]()
Limited time offer
