cybergal said:I was wondering can I just buy a receiver on ebay and plug it in?
will it work?
But if the installer of my DishNetwork system is the one who calls to activate it , they won't know the difference. He has to call to activate the other 2 receivers anyway.jerryez said:Dish may not authorize the 322 that you bought, since they are lease only and the property of Dish Network.
DON'T do that. You bought that 322, send an email to ceo@echostar.com after your install is completed to get YOUR 322 activated. IF your installer would get it activated it would be as a leased receiver and you would NOT ever be able to sell it.mailman390 said:But if the installer of my DishNetwork system is the one who calls to activate it , they won't know the difference. He has to call to activate the other 2 receivers anyway.
n0qcu said:DON'T do that. You bought that 322, send an email to ceo@echostar.com after your install is completed to get YOUR 322 activated. IF your installer would get it activated it would be as a leased receiver and you would NOT ever be able to sell it.
I bought a 311 and a 510 from private parties on EBay. They both work great and I had no problem authorizing them. Be careful of leased receivers and be careful for those who may have viewed PPV's and didn't pay for them!cybergal said:I was wondering can I just buy a receiver on ebay and plug it in?
will it work?
I guess E* considers it a re-lease. Know of anyone getting arrested and charged with possession of stolen property?bbtkd said:What it comes down to is that if you buy a receiver that is lease only then you have bought stolen property. It was not the property of the seller to begin with since Dish does not sell them - does not make it any more legal if the seller is a dealer. They could possibly lose their dealership if Dish found out. Then again, as long as they get their $5/mo they may not really care.
Could I try to call an activate it myself?n0qcu said:DON'T do that. You bought that 322, send an email to ceo@echostar.com after your install is completed to get YOUR 322 activated. IF your installer would get it activated it would be as a leased receiver and you would NOT ever be able to sell it.
But now that you can buy a 522 from a store, can't a normal (well not so normaln0qcu said:No, you have to use the email address and give them your account and contact info and the R# & S# from the receiver. Only a few CSR in the exectutive office can activate OWNED 322's & 522's. Normal first level CSR cannot activate.
Limited time offer
