burn in | SatelliteGuys.US
burn in
Not open for further replies.
You should not have that issue with a rear projection style tv.
It's the plasmas you have to worry about on the burn-in. LCDs will give you dead pixels... RPTVs will have a burned out lamp, or just a dimmer picture till the bulb goes out...
carlosg said:
Will widescreen movies on dvd burn in on a rptv 52inch
52inch. Is it a 4x3 CRT RPTV? If so, then yes, burn-in might be an issue. Turning down the contrast level may reduce the risk.
Rear projections will definitely get burn in with the black bars. Been there, done that.
Don't know where you got your Info from?
But ....YES....a RPTV can get "Burn-in" !!
http://www.avsforum.com/avs-vb/showthread.php?t=406182
How much do cords matter
First HDTV
