Buddy cleared ALL codes in the RC64R remote .... | SatelliteGuys.US
outerub
100
Michigan.
... and now it won't even control the HR22 !
It worked when I left after the install .... WHY can't people leave well enough alone ?
What can be done ?
Thanks,
UB. :)
To program the remote to control the HR22, you leave the slide switch in the DirecTV position, then press and hold "Mute" and "Select" until the DirecTV light flashes 3 times. Then enter the code "00001" and press select...this should restore control of the HR22, which will allow you to go to the setup menu and re-enter the codes for your TV and associated equipment.
50ft coax cable and rain fade issues?
Does D tv braodcast 3hr ahead
