bsc621 | SatelliteGuys.US
bsc621
Techfizzle
Banned
985
someone pm'ed me saying they had a bsc621 to give me, well i lost that pm, so whoever sent it.. please re-send it, and how well does it do on 4dtv? someone said they wont work well cuz its a universal lnb
why dont you do a search...that will get you the answer
there are 2 models...one works with 4DTV and one doesnt
another thing that made me made was that i bought a brand new c band lnbf off ebay that was voltage switched, going back to the made-in-china thing, the bolt holes were off by a half inch:eek: like they didnt measure them from and old one
so im going to save it until i get a dish with tri leg support
your 621 would, the lnb i bought off ebay is not.. its a lot smaller diameter
all of mine holmes
621-2
GeoSatPro C/K1
WSI DIgital 741
GeosatPro C2
Eagle Aspen stacked LNB
my old 25k units
all fit in there just fine. Some were smaller than the ring but they held :)
well goody for you, but the one i bought dont
it might fit in my micropak's feedhorn il try it tommorow
ok there junior...I guess ya need a different scaler ring
make sure you dont destroy the old one "because it didnt work" :rolleyes:
the micropak doesnt really have a feedhorn, so i dont know if a cband lnb would work without a scalar
A Re-Worked Tune
Can't get a signal, but why
