BSC621+QPH031 piggy back ? | SatelliteGuys.US
SatGuyPR
14
Clarke Belt
The KU side of my BSC621 is dead...
so I remove the three screws...
and piggy back an AlphaStar 1.0dB LNB
barrel type ... over 10 years old ...
Bottom line... it works...
Since this trick works... Im looking for other
game with that BSC feed horn...
Remove the plastic cover on the QPH-031
remove some ring metal... and attach it to
the BSC621 piggy back... now it will be a
tripple band LNB... CBand + KU-Lineal + KU-Circular
Anybody tried this ? ... Did it work ?
Our man, TruckRacer, has discussed a similar project which seems to have worked.
You can look for his previous comments about it, or when he wakes up tomorrow, perhaps he'll share his expertise. - :up
I did this trick with a c-band only lnbf (astrotel 20k) - I swear I think this old astrotel can lock any signal with little FEC. It must be super stable. I drilled a 1" or so hole in the back of and mounted a cheap chinese ku lnbf in the rear of removing the outer most scalar rings from the ku lnbf.
I used (Hillbilly style) liquid steel to stick it together lining up the probes.
I have had this on my 7.5' sami mesh dish for over 3 years and it works great.
I get great ku reception and c-band reception.
No problem locking G3-C equity mux or HBO's on G1 (G15).
Ku booms in.
Ku booms in.
Have you ever posted a picture of this rig?
I have searched & seen several posts where you mention it, but no picture:(
I keep amusing pictures, but don't always keep where they came from.
Below are some like what you are describing.
I don't know if any of 'em are Truckracers pix, though.
C-Band dish misuses
My 8psk s-2 drama
