If you use them with separate lines instead of using the internal switch, you'll connect to the one at the end of the lnb (for ku) and the one that says 'receiver' (for c-band). The one that says 'lnb' will not be connected.Which terminal due i conect my cable for C band?The one that says recever or the one that does say lnb I want to use both as seperate cable conections
Limited time offer
