Bsc621-2 C/ku Lnbf | SatelliteGuys.US
Bsc621-2 C/ku Lnbf
Eastcoast
343
Newfoundland,Canada
Has anyone used this LNB with a 1.2 M dish and if so what can you expect.I realize that with C band it would be experimental and does tit work well with KU?
Any comments would be appreciated as I may " kick it up a notch" with my FTA.lol!
Dave
I tried it on my 40" P* off-set dish with poor results (Picture below)
Remember it is designed for a prime focus dish and that you would need a specially designed scalar ring for an off-set dish.
I know Scott (Our esteemed leader) is thinking about a similar project.
Ok Pete so the scalar ring that comes with it is no good for an offset dish and has to use a deeper cone shaped one like your picture. That one looks like the way the KU type are designed except smaller.
where o where?
Hi all, first post here. I am also looking for this deep dish scaler ring kit. This is what I have found.....in Japan. I have not been able to locate in usa. Anyone else had any luck?
Hello and WELCOME to the SatelliteGuys.US FTA forum :)
:welcome
Gona point the Ku dish for HD
