BSC 621 | SatelliteGuys.US
BSC 621
PKII
791
19
WV
I just got my BSC 621 from Sadoun. :) No instructions included. :( but I did get a cool Sadoun pen. :)
Anyways it came with a di-electric plate to receive circular polarized signals. What are circular polarized signals? Should I install it as instructed? :)
there are some satellites across the atlantic that are R & L polarity instead of H & V in which you need that inserted
for sats from 58-139W C-Band its not needed
Oh ok. Thanks.
This di-electric plate have any uses? Feels like a piece of glass to me. :confused:
I have had one for about 1 month now, its great but will take some time tuning and tweaking. One thing I found was the simple little feed horn cover needs to be right on the end, do not push it up into the feed horn to the stops. It may take a little silicone to keep the cap in place at the end. I had pushed it up to where it hit the stops inside and that actually hurt the signal I found. I get very good results from my 621 but I did have to spend some time with it.
Humm..the LNB doen't even fit into the ring. I guess I gotta file off the paint. This is stupid. I just paid $49 for something I gotta file. :rolleyes: Well I finally got it to go on. What number should I start off with. 2,4,6,8,0 or the 2 at the bottom? I have a Fortec 6 foot dish. :)
Installed my BSC 621. I took off my adapter for my Ku band and put my ring up then I just put in the LNB it started to rain so I just put it in quick and went back inside. I thought well I will aim and make sure everything is all lined up later......
Turn on the receiver not expecting a signal at all...... Perfect picture on all channels I had before. lol. :)
sat 129 white springs tv help
Slave Receiver
