Broadband over DISHCOMM? | SatelliteGuys.US
bradb007
SatelliteGuys Guru
145
Is a broadband connection shared over DISHCOMM?
My setup
622 w/ wired broadband connection
722 w/ dishcomm connected successfully to 622.
Will I be able to use the new dishonline features on the 722 or do I need to purchase a wireless ethernet solution for the 722?
Thanks!
I tried it and even having the units hooked up to the internet is useless for me. IT doesn't do anything and plus, if I ditch the telephone line, I loose Caller ID. If Dish ever get the internet rolling over here in Delaware, I would attempt to hook them up again. Plus, when I had the units hookedup, it would screw with my wireless router. I had to do a reset on the wireless router almost every three days. So, I pulled the plug and have no resetting issue now.
Attention dishnetwork sports department morons
Tonights NBA on TNTHD
