Broadband connection! | SatelliteGuys.US
Hmm, what happens when you test the connection. I'm not at home right now to check but I think the menu commands are "Menu > 6 > 3 > connection". This will test your phone and broadband connections.
Do you live in an apartment complex or any other multi dweling building where someone else might have a homeplug device? Also, why is it that you think it is picking up a broadband signal?
Same thought I had. Why do you think it is picking up a broadband signal?
You can pick up a neighbor's HomePlug traffic if they are just on the same transformer as you. So you don't have to be in a townhouse or apt for this to happen.
The trouble is that even though you have enough signal for an IP address, you may not get a very strong signal which could impact the download speeds.
I bet this is happing a lot more that people suspect.
Problems w/722 and Video/Sound Sync: 12/26 3:30 PM EST
Reset 722 Temp.
