Bottom/Top and/or sides are chopped off??? | SatelliteGuys.US
stlrsfn2k5
2
Recently, I have noticed my TV ( I mostly notice it watching sports where there is a sports ticker at the bottom) cuts off the bottom and or top and sides, its like it is zoomed in on the picture.....I'll be the first to admit I am not an expert on the whole 720, 1080 4:3 16:9 stuff, but I have HDTV from TWC and have a Panasonic 53" projection TV and up till now has worked great. The TV is still watchable, just annoying, just wondered if anyone had an idea where and what settings I should look at.....:D
Brandon
I don't know what kind of time warner remote you have, but with mine if you hit the# key it will zoom 1 then zoom 2 then normal. You may have hit this button by mistake if it works on your remote. It sounds like the first zoom on my remote, also you should have a picture size button or you can go in your menu to picture or setup for your tv and change it to the right look.
Distant Network channels
New Sports Channel for overflow
