BEV Installation question | SatelliteGuys.US
Knowstradamus
I'm trying to hook up my BEV 2700 receiver to my old DirecTV dish.
Question:
Do I need to replace the LNB?
Does anyone know the exact coordinates for Niagara Falls, Ontario?
Thanks in advance
Can you explain that, sorry, what do you mean by if all you want is 91? And do you know the elevation and azimuth for Niagara Falls or St Catharines ONtario?
The 18" DTV dish only acomidates one LNB. Even changing to a different type would not help picking up both of bells birds. Attaching another lnb next to the existing does not work well. Another dish could be installed pointing at the 81 bird and the two joined via a sw21 or a sw44/sw64. That DTV LNB would work fine that way. Easiest way to hit both birds would be a whole new Dish 500 style dish. That way you don't end up with a bunch of dishes attached to your house.
BEV aiming
2700 turns off and on
