BEV and TV Antenna | SatelliteGuys.US
BEV and TV Antenna
buldog
2
Currently have BEV with dual LNB's Four lines enter the house and are connected to a dish network SW44 dishnetwork multiswitch. Four out lines go to the receivers.
I want to add a tv antenna hookup. Is the sw 64 capable and compatible?
It shows that it can connect 5 feeds but can one of them be an antenna connection?
Is there any other multiswiches that will do the job?
welcome :wave
I don't think there is any Dish Network/Bell Expressvu compatibl;e switch that you can add an antenna to.
What you could do is put a diplexer in one of the lines coming from the dish. That would give you both antenna & EVu...you would need a diplexer on each of the receivers :)
You could also get rid of that SW44 and go with a Quad LNB..switch is built in (this wont work if you have 2 dishes)
Hey thanks for the reply.
I'll give that a try. I quess it does'nt matter what line I connect the diplexer to.?
SC Installation - West Palm Beach FL
Will Mpeg4 come to Canada??
