best way to install 6ft bud | SatelliteGuys.US
technically you are covered under FCC OTARD for up to 1m dish (39.6667")
as for the 6 footer....hate to say it but good luck. If they have specific rules then you might be OK. The HOA I live in they said the dish had to be on the edge of roof or on the deck
The 6 footer is on the deck so its my private property :)
I saw this rig a couple of years ago. It was a picnic table, pole through the center, and a big "umbrella" on top.
The "umbrella" was actually a transmission transparent cloth that let the signals right through it. In other words, the dish is under the "umbrella" aimed upwards and the umbrella is actually attached to the dish edge and the lnb enclosure. If you are on your deck, and can put your pole through a picnic table, and then sew up some lightweight cloth in the shape of an umbrella maybe you could fake them out,
Maybe the cloth they sell in the hardware depot stores that blocks out some, but not all of the sun.
Maybe paint the dish a charcoal gray
The best way to not get in trouble with the HOA is to come over to my place and put the dish in my yard! :D
If you know a couple of folks on the board, run it by them and try to convince them of the merits, they may go along with it.
Never lived in a HOA but knew a guy who did. He put up a BUD, the HOA told him to take it down. He appealed and showed them some sort of regulation concerning satellite reception and he got to keep his BUD.
Sorry don't have a copy of the regulations.
Getting the BUD going?
Another dumb question from a noob
