Best Way To Hook Up 922 | SatelliteGuys.US
rodder
2,351
105
Adairsville,Ga 30103
I have me AZBox Premium Plus And G Box Controlling My Dish.I Would Like To Keep This Setup And Hook My 922 Up To The Same Cable Can I Use A Dual Power Pass Spilter.
i seconded what sideswiper said. . .i have mind hooked up the same way with the diseqc swt on the stb side also. . .
once the 922 is on (plugged in) its constantly sendin power to the LNB(s)
I tried that with power pass on one side and the gbox will not work that way.then i tried power side to stb and open to 922 stb works fine but i get nothing on the 922.
o, so you just want the 922 to show pictures via the coax cable and your stb with positioner will do the rest.
well i have not done it this way as yet, but i will be gettin my positioner over the week so i will be sure to let you know what works for me.
but currently but 922 moves the dish and powers up my LNBs.
Traxis dbs3500 vs pansat 2800 or pansat 150m? help
DSR-410...so close
