Best satellites for my area.... | SatelliteGuys.US
Wildeye
53
I have a pansat 2700a and its slow as dirt when I'm blind scaning. I just wanted to know what are the best sats for my area to help save time? zip 33615
Sports feeds are mostly on SBS6 (74), AMC5 (79), AMC2 (85), IA8 (89)
News feeds are on AMC5 (79), IA8 (89) and IA6 (93)
Could you list how many tp your getting on each? I'm getting low numbers like sbs6 I get like 2 usable and amc 6 I only get 1.
Can't pickup any of the pbs channels on amc3. Is this normal?
In general I'm having problem getting anything above 12000mhz, what could this mean?
What kind of LNBF do you have? What does it say on it, any numbers?
If its a Standard the L.O. should be 10750
If its a Universal the L.O. should be 11250
Double check you have the L.O. set correctly for the LNBF you have!
I have a QUAD LNB POLOR LNBF. I had my setting at unversal 1. Now I'm trying univeral 2 on my 2700a
That HAS to be set at 10750 as the L.O. thats your problem :)
So linear side L.O. = 10750
Circular side L.O. = 11250
Change the L.O. then rescan the satellite, should get all the channels at exactly where they should be as posted in Lyngsat.com
Still no go with the INVACOM. Could it be an issue with the elevation?
10750 is defiantly the right L.O. for the linear side of the LNBF. Keep it there!
So you deleted all the channels from that satellite, changed to the correct L.O. then re-scanned.
Could be a pointing issue then, usually if you get one (weak) TP. peaked for signal all the rest will be there, they are all that the same elevation.
Well, since I've gotten the right lnb setup going I'm gettting more on my other sats. I've noticed if I tweek the setting by about .1+/- degress I get more hits. Just got done scanning that it .1- off. I'm watching the pbs now thax!
Balcony clamps
WHen the analog video will be banned from the satellite?
