Best multi switch | SatelliteGuys.US
Best multi switch
anhmduk
113
So. Cal
Looking to replace my multi switch in my on going effort to correct some issues I have been having.
Please give me some feedback on the multi switch you are running with any pros and cons. :) THANKS
I am running 2 HR20-700, 1 HR21-600 and 1 standard def receiver. All with 2 coax leads to them.
Zinwell 6x8,6x16
I think these are the only ones you can use with D* KA/KU.
Pros: It works
Cons: None
:up
For your set up, thats it, thats all there is, I doubt that you can buy them at the local stores, but D* will have them, IF they installed it originally , have them replace it, they should pay for it, if they did not install it, you can find them at many of the site sponsors at the top of the page.
Jimbo
Cannot Tune sats 103 & 99
Black screen problem
