The main problem with generic cables that come with equipment (I don't know which one you've got) is that usually they are not gold-plated. Which means they may work fine initially, but may develop problems over time due to oxidation.I'm using the cable that came with it. Unless you are going to have a run longer than the typical 8', don't waste your money on Monster.
Monoprice HDMI cables are all gold-plated. And cost as low as $3.96.
Monster is a waste of money - I totally agree. Especially with short-run cables.
Monoprice all the way. Some of the cheaper HDMI cables at local stores, or Amazon have loose fitting connectors, which I don't like. If you can wiggle the connection and it breaks up, that is a loose fit. I never tested an expensive HDMI cable, because I never bought one. All the monoprice cables I bought were always a tight fit, and they were $4 - $5 for under 10 feet.
Actually the issue with HDMI cables previously was that of brand connections were not solid.
That said, I think I paid maybe 5-10 tops.
Jimbo
No problem Jimbo, you sure have been here a while and posted a ton.Sorry Sonydude,
I posted this before I read your post, we pretty much said the same thing :up
Jimbo
I run a 50 ft monoprice hdmi cable and the picture is rock solid.
Trevor
No problem Jimbo, you sure have been here a while and posted a ton.![]()
Limited time offer
