Best Dish | SatelliteGuys.US
Best Dish
cmarcum
17
North Carolina
In everyone's opinioin ( at least everyone that reads this post ) what is the very best sat. dish with triple LNB I can purchase for High Def. DTV reception? I've got one I bought off ebay and one I bought at Best Buy. I still can't recieve a signal off Sat B. I've had some reply's to my other post on it and changed a couple things, still no signal. I'm going to try another location and thought I'd get another dish while I'm at it and want to get whatever is the best one. Can anyone shed some light? Regards, to all! :)
You May need To Get A Professional Installer. They Will Have Multi. Sat. Signal Meter. That Picks Up More Then One Sat. At A Time For Aligning.
Put your zip code in the setup menu and find out what your degrees are
before you install the dish set your elevation and skew to what it should be, then you can sweep the area to where your azimuth is....
having a meter makes it alot easier, or you can have your spouse or buddy yell out the window at you, if you want to save $'s ( LOL )
Wishing for the international Channel
Need Help Here
