Best dish choice for 5 feed setup? | SatelliteGuys.US
dogbert75
Hi,
I am new to this and looking to have a 4 recv setup, with one of them being a dtivo unit. Perhpas down the line changing some of the other units to dtivo as well. what type of dish should i have installed for my dtv? And will this be included in a basic install? Thanks for your help.
I don't know that you have an option. If you are in the Detroit area you will be getting the 5 lnb dish. If you are not you will be getting the 3 lnb dish. Both dishes have 4 outputs, so you would still need to employ a switch or multiplexer of some type, don't know cause I don't use more than 4 receivers. I'm sure the experts will be answering you soon.
In this case, a cascadable 4x8 or 5x8 multiswitch with all 4 outputs from the dish going to the inputs of the multiswitch.
This should be included in the basic install, but things like wall fishing all the wires would not be.
H
How to get HDDVR deal???
First post: Pertains to adding a DVR...
