Benefits of the easturn ARC | SatelliteGuys.US
broadcasttheworld
152
Thanks to Scotts review of the eastern arc we know pretty much that if you have a 2 dish setup now with 110/119/129/61.5 there is really no reason to upgrade from a PQ perspective. However having that setup in Ohio I never lose 61.5 in a storm only the others "61.5" is the wingdish. Are the eastern arc satellites more powerful then the others mentioned above? Since these birds are higher in the sky does that make them closer to the east from a distance perspective? Would this help with Rain fade?
Actually, yes they are closer. But the big improvement in rain fade is simply the higher elevation angle itself. Less atmosphere (and water) between you and the satellite.
IMO, the only "benefit" a person in Ohio would gain is the one dish solution and a 3rd DPP port (assuming you have a 2 dish, 2 DPP solution). From what I've seen, the signal level on the 72.7 is about 10 points LOWER than the 110/119 combo (averaging 62 versus mid to high 70s)
Remote and other issues
622 Keeps Restarting
