Bell ExpressVU Uplink Report - 8-22-2006 | SatelliteGuys.US
digiblur
14,190
4
Louisiana
The SatelliteGuys.US Uplink Activity Report - 08/22/2006 - 48 changes
Uplink Comparison Range: 08/16/2006 11:26P - 08/22/2006 06:07P
99 - DISFR - 91.0W TP 24 changed to (Not Available)
230 - SWARE removed from 91.0W TP 2
285 - VU-E removed from 91.0W TP 2
340 - HELP! removed from 91.0W TP 2
389 - DLIW - 82.0W TP 8 changed to (Available)
399 - SPRT* - 91.0E TP 16 changed to (Not Available)
419 - NFW - 82.0W TP 8 changed to (Available)
423 - NHLVU removed from 91.0E 12618
427 - NHL2 removed from 91.0W TP 20
428 - NHL3 removed from 91.0E TP 31
429 - NHL4 removed from 91.0E TP 31
430 - NHL5 removed from 91.0W TP 30
431 - NHL6 removed from 91.0W TP 19
432 - NHL7 removed from 91.0E TP 27
433 - NHL8 removed from 91.0W TP 7
434 - NHL9 removed from 91.0W TP 7
435 - NHL10 removed from 91.0W TP 6
436 - NHL-E removed from 91.0W TP 6
437 - NHL-V removed from 91.0W TP 6
438 - NHL-C removed from 91.0W TP 6
449 - RED5 added to 91.0W TP 8 (Available)
499 - DISSC - 91.0W TP 24 changed to (Not Available)
671 - PQ1 removed from 82.0W TP 29
672 - PQ2 removed from 82.0W TP 29
673 - PQ3 removed from 82.0W TP 29
674 - PQ4 removed from 82.0W TP 29
675 - PQ5 removed from 82.0W TP 29
676 - PQ6 removed from 82.0W TP 29
677 - PQ7 removed from 82.0W TP 29
678 - PQ8 removed from 82.0W TP 29
679 - PQ9 removed from 82.0W TP 29
680 - PQ10 removed from 82.0W TP 29
681 - PQ11 removed from 82.0W TP 29
682 - PQ12 removed from 82.0W TP 29
808 - RED4 added to 91.0W TP 8 (Available)
954 - Q107 added to 91.0W TP 19 (Available)
962 - WRN added to 91.0W TP 19 (Available)
967 - VPRNT added to 91.0W TP 19 (Available)
972 - WAHSA added to 91.0W TP 19 (Available)
8457 - RED1 added to 91.0E TP 25 (Available)
9880 - MLTI6 removed from 91.0W TP 6
9882 - STIS 91.0E TP 29 changed to RED3 91.0W TP 8
9888 - RED2 added to 91.0W TP 8 (Available)
9951 - MLTI1 removed from 91.0W TP 6
9952 - MLTI2 removed from 91.0W TP 6
9953 - MLTI3 removed from 91.0W TP 6
9954 - MLTI4 removed from 91.0W TP 6
9955 - MLTI5 removed from 91.0W TP 6
Channels in the system: 740
Picture Quality I assume... they weren't available to subs anways. They were on the same TP that used to be the one in 8PSK mode.
I didn't know ExpressVu used 8psk.
I thought all the TPs were QPSK.
I guess you learn something new every day.
It was a TP in 21500 SR 8PSK mode that had 3 or 4 encrypted streams of some engineering only channels. It was then switched to QPSK then the SNAP channels removed and PQ channels added. Now those have been removed. I haven't looked at the TP but I will see if it is still active.
They've been testing them for a good while. If they ever reach the point of replacing the 6000's they have deployed, they'll probably switch HD over to it. But that'll be when there's enough HD content to cause bandwidth problems.
Why not just add in the 8PSK module that the 6000 accepts?
No space crunch yet, so no need to send modules to all the 6000 owners.
If they need to go to 8PSK, probably easier to update them all to 6100's instead.
The 6100 (also known as the Dish 811) really suck though. They were always problems for Dish owners and most on avsforum admit they were never reliable enough for main units. The 6000 with its limited memory runs circles around the 811 (and even the 211, imo) as the ViP211 will lose video at the slightest error and requires a complete reboot and satellite scan before you can get a picture back - while the 6000 simply freezes on the picture and requires a simple channel channel to correct.
Schedule & Websites
9220 question
