Bell 5900 Question | SatelliteGuys.US
Bell 5900 Question
rougewhite&blue
6
Over the weekend, my Bell 5900 lost some programmed VuPass recordings. Luckily, I caught the problem in time and was able to record the programs manually, but when I tried to use the Search function on the receiver, it could not locate programming for TSN.
I can still view and record TSN, and its programming still shows in the guide, but the Search function of the receiver does not find anything from the channel.
Anyone have any ideas why/how this could happen?
Thanks for any help,
Jack
P.S.--Is there a way to make the receiver refresh the guide or force it to download the guide info again?
to force a guide either do a reboot (press and hold the power button on the unit for 10 seconds then let go) or as I have done on Dish boxes is this.
Does the 5900 have ajust the 2 day guide or does Bell have an extended one? If just the 2 day guide when you have the guide up press "44 right arrow" which skips to 44 hours ahead and most likely will download the guide. It works on a Dish box to do that
It has an extended guide. Usually it's good for a full week ahead.
I'll try the power button to see if it forces a new download.
Still not sure that'll have any effect on the Search function, though.
SC in Oregon
Star Choice Digital Basic Questions
