BBC to Test HFR and UHD streams at Commenwealth Games | SatelliteGuys.US
  • Thread starter Thread starter dfergie
  • Start date Start date
  • Replies Replies 0
  • Views Views 694
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
UHD streams, which have a native resolution of 4K or higher, (roughly four times the resolution of standard 1080p high definition) were already tested during the World Cup, earlier this year.
For the Commonwealth Games, BBC R&D is testing a higher frame rate - the speed at which images refresh on the screen - to reduce flickering.
"The high-frame-rate TV demonstration in the Glasgow Science Centre will show that this is even advantageous at 'regular' HDTV display resolutions, let alone for UHDTV," the blog states.
"A frame rate of 100 frames per second enables the human eye to fuse motion in a realistic way and is also high enough to avoid visible flicker."
The BBC is also experimenting with delivering live TV streams over internet connections, rather than via traditional satellites.
bbc.com
The ‘original’ Star Wars trilogy has been remastered in 4k
Sony Bravia TV antenna input shorted?
