Basic 2 dish setup for 61.5 and 72.7...what would I need? | SatelliteGuys.US
Ypsiguy
307
254
Ypsilanti, MI
Just for extra connections in the house and the fun of it I have decided to aim a 30 inch dish at EchoStar16 and a 39 inch dish at Nimiq5/Echostar23. I am aiming at the Eastern arc, obviously.
No DVR'ing involved, just a VIP 211k and maybe a Wally, since the circular polarity LNBF's will be dual. I have on order a Dish SW21 switch for the 211k.
Just want to hear any thoughts or if I am missing any little details.
Cool, thx for the input :) Will look for a DPP33 or 44.
Update: I have a DPP33 on the way!
Looks like a DPP33 does not need a power inserter. Correct?
Also, I have 3 actual DP LNBF's if the ones I ordered do not work, Krell. I would just need to fatten the feedhorn arm a bit with duct tape to get them to snugly fit.
Question for you all...does skew matter on a circular polarization LNBF? I know it definitely matters on a linear one.
Reactions: TheKrell
Also, I have 3 actual DP LNBF's if the ones I ordered do not work. I would just need to fatten the feedhorn arm a bit with duct tape to get them to snugly fit.
LNB polarity isn't skewed with circular polarity and it doesn't matter if you skew the dish if you're only looking at one satellite at a time.
As you probably know if the dish is looking at more than one satellite position then the dish has to be skewed.
HWS Software U717
Can I use an old 110/119 antenna on 61.5/72.7?
