bad LCD | SatelliteGuys.US
bad LCD
Jim S.
When someone asks you if you're a god, you say yes
5,803
1,558
FN11od
A few days ago my laptop's LCD screen, which is less than 3 years old and not heavily used, developed a flickering column of pixels. Now the entire column is permanently lit. It's not under warranty. Is there any source for cheap replacement screens? It's a Dell 17" widescreen.
Chances are, it is going to be cheaper to replace than to repair, at least that has been my exerience in the past. However, it may be possible to buy a broken laptop (with a good display), and cobble the two of then together into a working unit. I've done that in the past.
On the other hand, it could possibly be just a loose ribbon cable connection the display to the controller. (Have that happen, as well, too.)
Go to Dell online, browse to Support with the Service Tag number and click on Warranty info. Extend your warranty one year and then call Dell the next day to get your laptop repaired.
That sounds like fraud to me. :confused:
How can you "extend" a warranty that is already expired?
From Dell's site:
Important Note : Extension applies only to warranty and service terms still in effect. If your warranty and service term has expired, you are not eligible for this extension. For out of warranty assistance click here
From Dell's site:
"Extending" the warranty AFTER the warranty expires costs twice as much as it does if you extend it before it expires BUT Dell allows it.
Not able to watch video online
Any good online sources for premium photo paper???
