Backfeed Genie and a client | SatelliteGuys.US
harley1340
25
louisianna
I'm considering getting new service with Direct. I only use 3 tv's but have two more that will be used ocassionally, I'm not worried about HD so I want to back feed these two tv's thru coax from the genie and a client. Do they make a "dongle" to do this and would it be a "10 pin to coax dongle" or "componant to coax dongle". I looked on Solid Signal and couldn't find anything.
I think backfeed it the wrong term. That means using the same coax to send a signal in the other direction.
What you can do is have separate component feeds to the seldom used TVs using the 10 pin dongle for the component outputs.
What you want to do is use the breakout cable in conjunction with an rd modulator. This will convert the RCA to coax. Then you can use your backfeed line to other televisions.
Sent from my PG06100 using Tapatalk 2
Mounting dish on block wall question..
UNEXPECTED RESULT RECORDING REMAINDER OF SHOW IN PROGRESS
