cruzmisl SatelliteGuys Family Original poster Dec 29, 2004 114 0 Sep 9, 2006 #1 HI All, I am located in the 48236 zip code and am tired of rain fade on my 129 sat. I decided to use a separate dish 300 to pick up 129 but I can't find the correct azimuth and elevation. Anyone have any ideas? Thanks, Joe
D dougmcbride SatelliteGuys Pro Dec 10, 2004 184 0 Sep 9, 2006 #2 See http://www.sadoun.com/Sat/Installation/Satellite-Heading-Calculator.htm Enter 129 in the "Satellite West Longitude" box. I used Detroit MI and got 22.9 Elevation and 236.9 Azimuth. Last edited: Sep 9, 2006
C Clancy SatelliteGuys Pro Apr 3, 2006 436 0 Sep 9, 2006 #3 elevation of 23 deg. azimuth of 244 deg. Use a larger dish than the size you are using and you may get a 10 to 20 % gain. Last edited: Sep 9, 2006
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,461 15,188 Mankato, MN Sep 9, 2006 #4 if you want the National HD channels, swing that Dish300 to 61.5 Much stronger than 129
gdarwin Supporting Founder Supporting Founder Lifetime Supporter Feb 9, 2005 4,299 113 Lousville, KY Sep 9, 2006 #5 Iceberg said: if you want the National HD channels, swing that Dish300 to 61.5 Much stronger than 129 Click to expand... And it don't wobble...
cruzmisl SatelliteGuys Family Original poster Dec 29, 2004 114 0 Sep 9, 2006 #6 Ok thanks for the tip. If a tree isn't in the way of 61.5 I'll go with that, otherwise it's the lowly 129 for me.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,461 15,188 Mankato, MN Sep 9, 2006 #7 chainsaw will take care of that
