AzboxMinime | SatelliteGuys.US
AzboxMinime
bobsav2001
155
13
St rémi Québec Canada
Hi all.
Just received my AzboxMinime and i am very satisfied, i understand the menu pretty much.
The only thing i can't find is how to delete a single channel and just keep the one i like.
Is it possible to do it?
Thanks for your help....Bob....
Glad to hear you are satisfied with your new AzBox miniMe American Edition. Deleting a single channel is as easy as 1, 2, 3:
1. Press OK to display the channel list
2. Highlight the channel you wish to delete using the up and down arrows on the remote
3. Press the MENU key on the remote, select Delete from the popup menu and then Yes to confirm
Thanks pwrsurge for channel deleting from the list, now i would like to delete
a transponder from the list but how?
In 107.3 Ku CBC feeds i have 2 tp's 11941 and a tp that belong to StarChoice (Shaw).
Thanks again....Bob....
Unfortunately with the current firmware version, it is not possible to delete transponders from the list. However, you are able to delete transponders by installing the DSEdit for AzBox miniMe American Edition software on your computer available for download from our support page.
We will be adding the ability to delete transponders using the receiver on an upcoming firmware update.
Yalda Hakim replaced Mishal Husain on Impact - BBC World News
Anyone know where to get one of these cheap?
