Auto Hop And Partially Viewed Shows | SatelliteGuys.US
oldengineer
5,684
1,964
Lower Macungie Township, PA
I've got a problem with Auto Hop enabled recordings.
If I watch a show in its entirety with Auto Hop enabled it works fine from the Hopper or a Joey.
However if I stop the show after watching a portion and I resume watching from the Hopper or a Joey it gives me the option to resume from any formerly viewed locations and to enable or disable Auto Hop but it always restarts the recordings from the beginning with Auto Hop disabled.
The resume feature works fine for a non Auto Hop recording. I can start, stop and restart from any location and the recording correctly picks up at the selected point.
I reported it to Dish Tech Support and they say that a fix is in the works.
Model 211 or 222, using USB HD for DVR?
Hopper Questions
