AU9 dish roofmount for fta dish | SatelliteGuys.US
yes. The motor will fit on that mast
I use a 2 1/4" mast from my Shaw Direct dish to put the 36" dish/SG2100 on
It should work just fine. Does your roof mount have the two side supporting struts (aka mono-poles)? If yes, use them as well. It will make the pole pretty solid and will hold steady during wind storms.
KU Band question
Almost forgot the holiday
