I get a test failure on the H20 receiver "antenna test" for the 99 satellite, others 101, 110, and 119 pass, with very high signal strengths. Sure could use some advise.
Volrog,glad to see that you got the AT9 dish.:upVolrog said:Tested the signal strength on 99 (Network 11) this morning and here is what I discovered:
TP 3 - 98, TP 5 - 58, TP 7 - 75, TP 13 - 58.
Hi Volrog,sorry to hear that you're having issues with the dish in the evening hours.Hopefully,the tech will get you squared away tomorrow.:upVolrog said:Hey Steve,
got the AT9 installed on Wednesday, it works perfect until about 7:00 PM and then 101 goes out. Tech coming Friday to fix it or swap it out.
Volrog
Mountain Mike said:I was told by DTV that it needed to have "all pass". Thank you again.![]()
Limited time offer
