Asterisk's on Winegard SK3005? | SatelliteGuys.US
beliveauj
36
I installed the Winegard Traveler SK3005 today in my RV.When i ran the test and it came up *101*110 119 with no asterisk.Is this going to effect my signal?Still waiting for a couple of things to come so i can hook it up to the receiver and try it out.Thanks Jim
I believe that means it is getting 101 and 110 and not 119... 119 could be blocked. It can't detect the 99 and 103 but if you are getting 101 you will get the HD and everything should work fine.
If u didnt repeat sat setup and select slimline 5 with multiswitch you will not have hd. You have to have the b band converter installed also. I put one up last week in place of the tracvision r5sl dome. Let me know if u need more help!
How would he get HD? 101 is SD, 99 and 103 are HD
Yep thats why he needs b band. The wingard doesnt come outta the box swm. You can convert it to swm with a swm 8 and a lnb.
The B band converters will be here today then will see what i get.Right now using the slimline with swm on a post.Will let you all no how it works out.Thanks Jim
Well things didn't work out so good.I think the one or both the b band converters are bad.Going to pick up two from the DTV guy and try again.
Heres my email i can help u if u need? Bradcox5976 at bellsouth dot net
If u have bad b bands you just wont see 99 and 103. Everything else should work. Email is faster if u need help!
Yea jimbo it is. Camping world had it on sale a few weeks ago.
Its awesome youll love it!
Should still those 103
Must replace HD DVR defective must i renew for two more tears
Record 6 shows on single dvr????
