asp.net scripts | SatelliteGuys.US
asp.net scripts
rockymtnhigh
Hardly Normal
30,520
1,161
Normal, IL
Does anyone have any (uncopyrighted) asp.net scripts you might be willing to share? I am moving my personal web presence to the University's server, and they support asp.net, but not cold fusion (making it impossible for me to use many of the CF scripts I have used for authentication and more importantly email form processing), and I am trying to hunt down a few scripts (again, most important is form processing) .
cold fusion is a bit more simple than .net, if you need help post questions.. but no scripts will work 100% for your needs.. what kind of form processing are you looking for.. send an email out based on form values?
Yes, exactly that.
I know that CF is more simple; but I doubt I can convince the Dean's Office to purchase it.
CF isn't quite as popular as it once was.. gimme a few I should be able to whip something quick up for you..
Thanks much.
I always liked CF; and Ben Forta's CF Applications books are among the few computer books I could actually make sense out of! :)
This should work.. mind you I didn't test it.. but it's fairly simple so I don't expect issues with it :p
Code:
Dim msg as String = String.Empty
For Each key As String In Request.QueryString.Keys
    msg &= key & "=" & Request.QueryString[key]
Next
Dim smtp as System.Net.Mail.SmtpClient = New System.Net.Mail.SmtpClient()
smtp.Send("from@from.com", "to@to.com", "subject of email", msg)
You can change the QueryString to Form if you're using POST rather than GET, obviously change the from/to/subject
Code:
Next
Thanks, I will play with that when I get a chance later today.
Well, I'll be honest, in that Vince's code was a bit over my head; however, further digging online enabled me to actually implement a email processor that is working pretty smoothly. I integrated it into an existing dreamweaver site; and even set it up so that it cc's the message to the sender, uses a reply-to so that when I receive it, I can just hit reply.
I am pretty pleased; but still think I will end up at Borders and look at their Asp.net books; since the server is only running asp.net 1.1 I might be able to get some of the older books for cheap. We'll see.
BTW, the page I created is here.
The code I used follows:
Code:
< % @Import Namespace="System.Web.Mail" %>
< script language="vb" runat="server">
Sub btnSendFeedback_Click(sender as Object, e as EventArgs)
  'Create an instance of the MailMessage class
  Dim objMM as New MailMessage()
  'Set the properties - send the email to the person who filled out the
  'feedback form.
  objMM.To = "****************"
  objMM.From = "**************"
  objMM.Headers.Add("Reply-to", txtEmail.text )
  'If you want to CC this email to someone else, uncomment the line below
  objMM.Cc = txtEmail.Text
  'If you want to BCC this email to someone else, uncomment the line below
  'objMM.Bcc = "someone@someaddress.com"
  'Send the email in text format
  objMM.BodyFormat = MailFormat.Text
  '(to send HTML format, change MailFormat.Text to MailFormat.Html)
  'Set the priority - options are High, Low, and Normal
  objMM.Priority = MailPriority.Normal
  'Set the subject
  objMM.Subject = "Web mail"
  'Set the body
  objMM.Body = "At " + DateTime.Now + " An Email was sent from Dr. Gizzi's webspace " & _
               "Below you will find the message " & _
               "sent by " & txtName.Text & "." & vbCrLf & vbCrLf & _
               "---------------------------------------" & vbCrLf & vbCrLf & _
               txtMessage.Text & vbCrLf & vbCrLf &  "Email address: " + txtEmail.Text
  'Specify to use the default Smtp Server
  SmtpMail.SmtpServer = "*************"
  'Now, to send the message, use the Send method of the SmtpMail class
  SmtpMail.Send(objMM)
  panelSendEmail.Visible = false
  panelMailSent.Visible = True
End Sub
< /script>
And then I just used asp panels inside the webpage.
My next goal is to figure out if I can have an attachment sent as well.
Online versus store front
Gaining permissions on a master drive
