ariza extreme over heating? | SatelliteGuys.US
amc1
i wondering if my ariza extreme is over heating?it loosing signal if i switch it of at the back and leave it for a while and switch it back on it works for a while .then the same thing happens ,also wondering if g10r is experiencing any problems?:confused:
It could also be the LNB drifting as it heats up.
Easy way is to replace the receiver if you have another.
That's not 100% sure-fire test,because a different receiver may be more frequency tolerant.
You could try entering your transponder frequency a little higher or lower, to see if that helps.
And yes , of course, it could just be the receiver. :)
Actuator arm on 1.2m dish
Fortec FS6D 1.8m Dish
