are Slimline dishes interchangable? | SatelliteGuys.US
sjmslik
Assuming you have matching reflector, backing and arm are all slimline dishes the same. by this i mean if i want to put an sl5 on instead of an sl3 can i use my existing slimline dish and just repeak it?
Yes, wat you said can be done and you really should not need to repeak it, however you may want to run the Repeat Sat Set up just to make sure it sees the correct dish and lnbs
Sent from my Samsung Epic using SatelliteGuys
HR24 stuck on 0x4d
Homeland on Showtime - HD?
