April 4DTV "trip" counter observation | SatelliteGuys.US
Corrado
2,443
334
Hudson Valley Region, NY
I noticed that my 905 and 922 subbed receivers have not received a single "trip" on the counters in April. In the past, I noticed the 410, when subbed, received far fewer hits in comparison to the 4DTV. But, at least a few per week. Perhaps the ACC changed something?
The 905 and 922 used to register at least 6-8 (?) per day.
Both receivers are still working as always even without the end of the month key change that normally occurs on the last night of the month.
now that you mention it, I don't think mine changed much either recently.
But end of march the trip counter reset to 0. had not seen that before.. it was around 300 prior. now it's at like 20
Mine changes daily some days more than others. If you hang out on G3 you won't see any action since NPS has no data stream. If you do hang out on the premiums or W5 channels you should see activity. Im not real sure about the Discovery's and Scripps channels and the like what's active with the data stream. My hit counter is at 4936 Im on a UPS and been up solid for over a year now, want to see if it hits 9999 what it will do :eek:
Research Channel (11805) on 123W Quality Drop?
10ft KTI setup
