Apartment System upgrade | SatelliteGuys.US
pdubs23
Rochester, NY
Hoping to get some help or ideas here.
We have a complex we service with 200+ units.
Each unit has a home run to one of several (10) services boxes outside.
The previous installing company placed DP34 switches into each of these service boxes with 3 to5 switches in some with 2 lines back to a DP quad head on 110 + 119 (4 lines total with 2 going to a set of stacked switches).
They are using 211k receivers.
The biggest issue with this setup currently is being unable to provide HD programming from 61.5 & 72.7.
Is there a LNB + Switch setup that would help without having to get power into the box to each switch? (using the power from the receivers or other)
Thanks for questions, answers or ideas.
Although it is not ideal, the LNB for 110 and 119 can be re-aimed for the 61.5 and 72.7 satellites. The spacing between the satellites is slightly different (11.2 degrees apart instead of 9 degrees) but some people have reported getting it to work. Signal strength will be slightly lower due to the aiming being slightly off. The people who posted success with this did not have an installation anywhere near as large as yours, though.
Adding 2nd hopper?
No Netflix 4K on 4K Joeys
