Anyway to get 91w by adding an lnb to a dish 1000.2? | SatelliteGuys.US
usudno
3
Was thinking about getting a bell express vu sub so i can get the fight network and NFL sunday ticket (dish doesn't offer either) but landlord only allows one dish (currently a dish 1000.2) can i poorman onto that dish another lnb?
eh it might be tough but can be done.
One time for gits & shiggles I had 110/119/129/148 on one dish. 129 was the middle...110 was a little weak but fine. Take the fact that 110 is right now to the left you would need 2 LNB's past that. You can try but I wouldn't expect miracles
comcast
very good use of dishpro plus. have you tried the 36" superdish pan with the 1000.2 lnbf? the focal length might need to be adjusted.
so it would be 2 lnb's past the left most (looking from behind the dish towards the sky)? Just trying to make since. Which Lnb is the 110? It should be 2 lleft of this one correct?
I goofed...its to the right
when dealing with multiple LNB's they are bass ackwards from the way in the sky. So when you are behind the dish looking sat the LNB's it shows
129 119 110
trying not to set up a whole new dish (and old DTV lnb is much cheaper haha) Thanks guys I'll try. So if i were to tirap two lnb's together then try to find the signal like that I'll get something?
Star Choice Quad 75E LNBF Issue
Help With Switch Problem
