Anyone use this for sealing? | SatelliteGuys.US
I have never used it, but as long as you have you conncetions the way you want it...I don't believe it would hurt to try it out.
Yeah, can't really complain about the price if I don't like it. I can find 10 cans on the side of the road for bottle returns to offset the price. :)
IMO you may be sealing in any moisture (In the future)
I use Dielectric grease in all connections! NEVER had a problem since I started using it around 5 years ago!
I've got about 6 rolls of that stuff (picked it up when it went on clearance). Works really good. Use it all the time :)
cmon now, lets not start any vicious rumors. :)
Btw, picked up some of that coax sealent after work, Out the door for 80cents.
New C Band Feedhorn Design
Diseqc switch
