Anyone use a ReplayTV with the 622? | SatelliteGuys.US
horseflesh
48
I am thinking about the 622 upgrade, but I use a ReplayTV to timeshift SD programming. Since the 622 is multi-tuner I am not sure if you can successfully control it with an IR blaster--what tuner gets focus? (Heck, I am not even sure if it has an IR remote... that's something else I need since I use a Harmony universal.)
(I know the 622 is a DVR, but I'm not willing to give up my automagic commercial skipping. I'd use the 622 only for recording premium HD shows, and the Replay for everything else.)
Thanks for your thoughts.
I use Replay's with my 622 and 921 but only to archive, have never tried hooking the blaster to them... Have same one hooked up most of the time to a Sammy D* HD box, One hooked to an 811 (soon to be replaced by a 211) and another hooked to an H!) D* HD box..
I use my Tivo Series 2 on TV1 of my 622 and control it with the IR blaster from the Tivo. The Replay should be able to do this also. I used the same IR blaster settings I had with my 510.
What are transponders for?
Has anyone purchased from Dishdepot.com?
