Anyone use a "Horn" antenna for Ku? | SatelliteGuys.US
VERY Interesting thanks for posting. I messed about with a home made Horn I made from an oil can in the 80's
May have to look into it again!
The horn would need to be incredibly long for a beam width less than 2 degrees (can't imagine a 1 degree BW horn).
OK how long should the antenna that I listed be if I wanted 4 degrees?
From J.D. Kraus, Antenna Book. For 6 deg. Beamwidth; horn length would be 70 wavelengths and Flare Angle would be 15 degrees.
It's hard to interpolate from his graph, but 4 degrees would be about 170 wavelengths and a 13 degree flare angle.
similar to QPH-031?
119 music
