Anyone tried Viewsat Max HD for NBC? | SatelliteGuys.US
gdavisloop
74
Anyone tried the Viewsat Max HD (or Viewsat 9000) on the NBC DVB-S2 8PSK feeds? (C band or Ku band?) Any luck? Anyone found another receiver that works well on these feeds? For the record, I've tried the Pansat 9200HD and the Coolsat 9100 and the results are 'mixed' - to put it politely.
thank you,
--Gary
There should be no issue with the Coolsat 8000 / 8100 or Pansat 9200 w/ proper Add-On tuner.
I used a Diamond 9000 with no issues.
NBC's 8PSK/DVB-S2 feeds are not 4:2:2; you're thinking of their old SD-Ku feeds.
--Gary
on AMC-1 they are 4:2:2, a Qualitv or computer will be needed to tune them in.
on AMC-18 they are dvbs-2 8psk, now a Cool-8000 & 8100, Diamond-9000 or Pansat-9000 or 9200 with the extra tunner, or computer will tune them in.
don't know about the Viewsat Max, I know the Viewsat-9000 will not tune any S2 stuff, that was my only Viewsat I have owened, an it was 1 to maney for me.
Corotor II Plus Assembly/Install Questions
How much signal quality should I expect
