Anyone knows of an installer in Los Angeles? | SatelliteGuys.US
Post in the FTA fourm. You might get a better response from there, plus alot of friendly advise if you decided to do the install yourself.
ninja4u said:
I have a Fortec 33" with rotor and a Collsat 4000 Pro.
Sorry to hear that the guy I referred you to did not come thru. I only know this guy because I purchased a 1.2m dish from him and he always mentioned that he did FTA installations, and that's the reason why I sent you his email to begin with.
I have done 3 installations myself so far with all the components you have (HH Motor + FTA dish + FTA receiver) and to be honest with you, it was not difficult at all. Especially the first time I did it.
You have not considered doing this yourself to give it a try?
Do what I've done. Take all installation components, and also take the receiver and a small TV or a portable 7",8" or 10" DVD player that has video inputs.
And that way you will save a lot of hours tweaking the dish.
I'd give it a shot, then if you determine that the chore is something way too difficult to do, then try looking for someone for professional assistance.
Good luck pal, and let me know how it goes if you do it yourself. :D
installing coolsat 33"
Equity feeds on G10R down???
